ā2008-12-18 06:47 PM
ā2008-12-21 01:27 AM
ā2008-12-21 03:48 AM
Karl wrote:So it's on Mac only, then?
This is some minor bug
ā2008-12-21 06:48 AM
Rick wrote:Well, maybe it was part of the cause? Ralph, with his gazillion files would best be able to tell us by timing before and after deleting them. When a new file is created at startup, ArchiCAD must be checking all existing files in that folder to make sure that the new file name is unique, which would take a little time, but I wouldn't think it would be dramatic.
All this aside, if that was not causing the slow start ups, I wonder what I deleted that fixed it?
ā2008-12-21 07:10 AM
Karl wrote:Hi Karl,
Vistasp: I don't have a Windows machine awake right now, but you could check in Documents and Settings\username\ and look down into Application Data subfolders or Local Data subfolders to find where the WE stuff is saved on Windows....might have the same problem?
ā2008-12-21 09:16 AM
Karl wrote:The same thing happens on Windows XP SP2 (C:\Documents and Settings\
ā2008-12-21 02:27 PM
vistasp wrote:vistasp:
I'm still on AC10 which has no such problem. I asked only because I've been contemplating an upgrade. So far the sheer number of bugs that you guys have found, has discouraged me from taking the plunge.
ā2008-12-21 05:38 PM
David wrote:Thanks David, that's encouraging. You're right that this doesn't affect AC's operation but what I'm more concerned about, are the bugs in library parts. Does anyone have a clue when they'll be (mostly) fixed?
The new features and speed increase in 12 are worth the upgrade, all the versions have some bugs, but for me 12 has no bugs that make me wish to use any earlier version.
ā2008-12-21 07:28 PM
ā2008-12-22 04:09 PM
Bier wrote:This is completely consistent with my experience. Shutdowns were taking a long time (even when performed without a save). Deleting the 315 WE ProfileSetxxxxx.xml files I had accumulated returned my shutdowns to instantaneous.
I had been having long waits on shut down, not start up. Since I just deleted the profiles sets listed above, AC shuts down instantly...
ā2008-12-23 12:40 AM
