This is starting to look like there is something basic that you have done which you are not aware of and it is causing the problem.
Items to troubleshoot:
- Open a New file using "launch a new instance" and using one of the basic templates so that you have 2 AC copies running concurrently.
- Select wall on first file and copy paste it to the second one
If the window shows correctly in the new file then it looks like you have modeled something wrong in the First one.
In this case possible causes beyond assigning the wrong Reno Filter is that you have one wall on top of the other.
If the wall copies without a window to the new file then that means that the window is not within the correct wall and the other wall is covering it.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08Mac Studio M4 Max 64GB ram, OS X 10.XX latest
another Moderator
