Java Runtime Environment problem
I have AC9. Old computer ('03 dell laptop) died. When installing AC 9 cd on new laptop I am told that the JRE is not installed properly or out of date. etc.... I have reinstalled from disk, downloaded latest java from website, restarted a dozen times. I think I have all the pieces but they in the wrong place. Any ideas? Thanks
4 Replies 4
Eduardo Rolon
AC09 does not install in Vista for a possible workaround check the Wiki.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thanks. I have XP pro sp2. I bought laptop with both loaded, but XP boots. Is the dormant Vista the problem?
Eduardo Rolon
Checking the Wiki
www.archicadwiki.com/TechNotes/Installing_ArchiCAD_9_requires_Administrator_Rights?highlight=%28install%29
AC29 US/INT -> AC08
Ejrolon,
Thanks so much for your input. As I exited from the forum. I decided to try a method from another subject: Java Block. I removed all Java Runtime apps and Loaded up install CD. It all worked perfectly. Thanks for your assistance.
Warren
