Kitchen and Household 11 objects
Is anybody having problems with the sink objects not showing a perimeter outline at the edge? More specifically please look at "Multi Style Sink 11". I can't get a line to show for the edge of the sink, not the hole but the edge. On ver 10 it shows but on ver 11 not? What am I doing wrong?
6 REPLIES 6
Laura Yanoviak
In AC11, there's a new "Sink Undermounted" parameter. If I remember correctly, the library parts are set to "undermount" as the default.
Thank you. That would make sense, where is the switch? I am having trouble finding it.
Laura Yanoviak
Right here:
Laura,
He's talking about a different part, which has no "undermount" option. I'm sure it's easily fixed by someone who knows GDL, but that leaves me out.
Anyway, for now, I'd just draw the rectangle in as 2D CAD and be done with it.
Richard
AC26 (since AC6.0), Win10
Laura Yanoviak
Ah -- sorry about that -- wasn't paying close enough attention, but now it does come back to me: the sink macro has a parameter for the undermount setting that is missing from the Multi Style Sink object (so it defaults to the setting in the macro: On). All one has to do is add the parameter to the sink object so it can be switched Off -- attached is the Multi Style Sink for those who aren't GDL savvy...
Thanks, Laura. Works perfectly now!
Richard
