2008-06-08 05:49 PM
2008-06-09 08:40 AM
the other two will at first display the info correctlynot sure what you mean by the info...
2008-06-09 10:54 PM
2008-06-10 09:04 PM
2008-06-10 09:11 PM
2.info = drawing, plan, whatever is on the screenthe other two will at first display the info correctlynot sure what you mean by the info...
3. try to redefine the viewpoints again, note if you have changed the layer combo's name the viewpoint will not recognise it (known bug), so change the layer combo to whichever you need to and then re-save the viewpointi already tried redefining the viewpoints...
4. refresh the drawings on layouts or eventually delete wrong drawings from layouts and place them on againalready refreshed them, tried the delete and re-place them method, everything is ok until i switch to plan view or close and reopen the document. then everything disappears again
2008-06-10 09:12 PM
Djordje wrote:but...i am using layer combinations...
Also, WHEN IN LAYOUT, show and unlock all layers.
2008-06-10 10:16 PM
ICEdevil wrote:
today i found out that someone else at a local architecture firm has the same problem, so he uses multiple stories instead of layouts... 😕
2008-06-10 10:54 PM
s2art wrote:i'm sorry...i'm a jackass...i meant "instead of layer combinations"ICEdevil wrote:
today i found out that someone else at a local architecture firm has the same problem, so he uses multiple stories instead of layouts... 😕How? In what way? Do they not use layouts at all?
2008-06-10 11:31 PM
2008-06-10 11:48 PM
s2art wrote:well...i don't know that... =))ICEdevil wrote:
i'm sorry...i'm a jackass...i meant "instead of layer combinations"![]()
That's just as bad.
What do their sections look like?
