ā2024-11-22 11:10 AM
If you had to choose between the following - what would you choose:
M4 Max with 14 core CPU and 32 core GPU with 36GB ram w/- 410GB/s memory bandwidth
M4 Pro with 14 core CPU and 20 core GPU with 48GB ram w/- 273GB/s memory bandwidth
Both are roughly the same price. (its another $750 to get the Max with 48GB...
My current 5yr old PC laptop has 64GB Ram - it appears to be rarely all used. It rarely pops over 50% - even with 4 archicad models open, one large revit file a dozen Chrome windows (that seem to take up the most RAM)...
Will the faster bandwidth and faster GPU be more useful / better than the RAM?
My daily work is probably 30% archicad use using teamwork files that are >1G... large apartment buildings, complex houses and urban projects... don't do much twinmotion rendering... spend lots of time cutting 2d and 3d sections... viewing different parts of the model to check and make quick amendments.
ā2024-11-27 03:47 AM - edited ā2024-11-27 03:48 AM
Memory in an Apple silicon cannot be compared apples-to-apples to memory in a pc because an Apple silicon is a SoC (System on a chip), meaning it is not only the CPU, but other components as well, like the GPU, memory, etc. So, the CPU, GPU, and memory are all on a single chip, and what is important is that the CPU and the GPU are using the same 36 GB or 48 GB of memory (it is called Unified Memory).
So, if you say you need 32 GB RAM for the CPU, and maybe another 8 GB for the GPU, that is already 40 GB. Plus, you would want to future-proof it so the memory is enough 3 or 4 years from now when you may still be using this machine and newer Apple macOS versions and applications need more memory for both the CPU and GPU.
In conclusion, I would go for more memory, in this case, the 48 GB.
ā2024-12-27 06:46 PM
Iām facing the same choice.
I use a first gen intel mbp16 with 32gb of ram. Iāve always felt that CPU was more of a limiting factor than Ram as I can work on large files (more than 1gb) and it works fine, itās just slow to open files and rebuild 2D sections and elevections.
I tend to think that the faster the cpu, the faster Iāll work on large files.
Anyone has any insight?
ā2024-12-27 09:43 PM
If the CPU is the most important factor in your work, you should look at the CPU's single-core performance. That is the more important metric for a BIM application, not multi-core performance, which is important for certain areas like rendering.
ā2024-12-28 04:14 AM - edited ā2024-12-28 04:20 AM
Memory speed will have the biggest impact comparing the two. I wouldnāt hesitate to get the max for that reason (and why we have both an M2 max and M4 max) Also, the additional GPU cores help support multiple monitors while keeping the Mac cool. Weāve never had the fan come on for either the M2 Max or M4 max MacBook Pros, each with 2 external monitors ⦠yet the previously highest end Intel Mac was blasting heat (and noise) most of the time.
The additional cores will better support the multiple Archicad you are running. I presume youāll still use the older PC for Revit, But, you can run Intel apps via a virtual machine (Parallels Desktop is what we use) running Windows 11 ARM on your Apple Silicon Mac. Windows 11 ARM (installed by PD) has its own emulator for Intel apps. Might check around to be sure nobody reports issues with Revit in that environment.
ā2024-12-28 09:58 AM
Thank you Karl!
Your return is a great help.
Following your experience, the base m4 max (highest I can afford) could run smoothly?
I mainly draw houses, small schools and occasionally residential buildings of 50units.
ā2024-12-28 05:10 PM
Yes, it is an amazing machine and should perform well for you.
ā2025-01-10 06:44 PM
Hi Karl,
just an update on this topic, I have purchased a base model 14 inch MBP M4 Max and it's the best MacBook I've owned so far (my fourth). It's super fast, the fans never engage except with twinmotion and even in this case it's 50% quiter than the intel MBP I've used in the past.
Can't say for the lower spec though.
Thanks for your helpful opinion.
Cheers.
ā2025-01-12 04:41 AM
Fantastic! I'm about to do the same in the next week or so.
My only concern was the 36GB RAM in that version. How many models can you open at once before the RAM max's out!
(I know part of the solution is just to open the files I am working on and not have 42 tabs open in Chrome!)
ā2025-02-12 12:02 PM - edited ā2025-03-25 10:35 AM
Where do you experience the performance?
I often experience waiting time when updating sections (with engineers' IFC turned on), publishing, updating schedules. My impressions is the that many of the processes i my work is single-core and that my CPU is not that good in single core performance.
I work medium to large projects in teamwork files: apartment buildings, museums, spa. (Eg. 260K polygon 3gb solo file.)
Your insight is much appreciated.
