Installation & update
M4 Max or M4 Pro
psmith
If you had to choose between the following - what would you choose:
M4 Max with 14 core CPU and 32 core GPU with 36GB ram  w/- 410GB/s memory bandwidth
M4 Pro with 14 core CPU and 20 core GPU with 48GB ram w/- 273GB/s memory bandwidth
Both are roughly the same price.  (its another $750 to get the Max with 48GB...
My current 5yr old PC laptop has 64GB Ram - it appears to be rarely all used.  It rarely pops over 50% - even with 4 archicad models open, one large revit file a dozen Chrome windows (that seem to take up the most RAM)...
Will the faster bandwidth and faster GPU be more useful  / better than the RAM?
My daily work is probably 30% archicad use using teamwork files that are >1G... large apartment buildings, complex houses and urban projects... don't do much twinmotion rendering... spend lots of time cutting 2d and 3d sections... viewing different parts of the model to check and make quick amendments.
Smith & Tzannes
Director
Archicad 28 | Windows 11 | MacOS | iOS | BIMCloud SaaS
21 REPLIES 21
Thanks for the info, btw did you get a MBP or a mac mini? am thinking of using MacBook Air if instances I need to work when I am travelling.
WINDOWS 11 PRO
Pavel_N
Hi, does anyone here have a Mac Mini M4 Pro 16gpu version? I would like to ask for your experiences with fan noise during high load, especially with Twinmotion, Archicad point clouds.. I know that people don't complain about MacBooks and Studios, but I found very negative experiences on forums with noise of the M4 Pro Mini. Thank you!
Setup info provided by author
