a month ago
Just upgraded from AC28 to AC29 Int.
The MEP Work Environment is not listed so I can't access all the tools associated with MEP stuff.
The WE listed are "Architectural Profile 29" and "Structural Engineering Profile 29"
Should I import the MEP one from the old ArchiCAD 28 work enviros?
Operating system used: Windows Windows 11
Solved! Go to Solution.
a month ago - last edited a month ago
Do you have a Archicad Studio licence?
If you do, then that might be it. Archicad Studio does not have MEP features.
If you do use MEP stuff, you would need Archicad Collaborate.
You can read the FAQ here at the bottom of the page.
a month ago
No sadly its the full version. I've done a repair install but no luck. Now whats "nippin ma heid" are a chunk of the MEP Library objects are not loading as they were modelled in AC28 but with the current libaries plus migration libaries loaded the dreaded black dots everywhere. So I'm going to extract them from the AC28 MEP LCF file and see if that sorts it.
a month ago
I've decided to go back to ArchiCAD 28 as AC29 the ductwork is "locked" even although it isn't actually locked either with the Edit menu command or on a locked Layer so I can't correct some of the ductwork.
In addition the very thing AC29 is supposed to do which is to show the ductwork in "Schematic" display isn't working either.
Finally the fact I've no MEP Work Envrionment so no access to the MEP tools and toolbars makes it impossible to use.
Very annoying 😞
4 weeks ago
First you mentioned you had the full version and not studio. So that means you should be able to edit MEP elements.
The other thing I can think of is that you originally said you upgraded from AC28 to AC29 INT, Did you perhaps change Language version from 28 to 29? not that it would matter for the MEP workenvironment profile, it should still be available on all Language versions of AC29 Full (although there was a year that in the USA version both the MEP & Structural WE's were excluded for some reason).
But with regards to the library parts not loading correctly, if you are still using the monolith library and you switched language versions I can see how you may get missing library parts.
I'd reach out to your local techsupport, because based on what you are describing it should work.
4 weeks ago
Thanks for your suggestions. I upgraded from AC28 INT to AC 29 INT. The actual Library objects which were modelled in AC28INT are displaying but I'm not sure if in AC29 they are using the correct Library and or have been updated to AC29 versions. I've reopened the file and did "Library Migration". It firstly said it couldn't find the "Monolith" Library but I've added it manually.
In AC29INT when I switch to a Model View Option using "symbolic" nothing happens I can see the outlines and the centreline of the duct. Whereas in the MEP Demonstration Model it does work but in both my Model and the Demo Model the objects are weirdly locked even although the layer isn't locked and I've done the Edit/Unlock command.
As you say I will take it up with the local ArchiCAD Tech people to see if I can get it sorted.
Thanks again
3 weeks ago
Apologies, I found out today that we don't have the full version of ArchiCAD but the poor mans Studio version. We did have the Full version till recently but I missed the discussion about changing to Studio. Seems a shame that AC28 has the MEP tools but you have to stump up yet more cash for AC29 with MEP tools. Almost like Graphisoft are teasing us.
I have managed to get the graphic overide to work in ArchiCAD 28 by using a white pen colour to display the ductwork in a Schematic way combinded with using the MEP scheme settings.
I've also learned lots along the way.
