Installation & update
Mac Power Book Pro won't install Archicad 10?
I just got a new mac power book pro and need to install archicad 10, after inserting the program disc and waiting indefinitely, nothing happens, it appears as though the computer is thinking& thinking & thinking. could it be that the computer i purchased only has 512 MB of memory or should that not hold me up when initially installing. what else might it be???
15 REPLIES 15
TomWaltz
Did you try double-clicking the installer program on the disc? Or did you just put the disk in?
Tom Waltz
yes, i click install and the install dialog box opens but then nothing
TomWaltz
It is the Intel version of Archicad?
Tom Waltz
I don't belive so. But from my understanding, the program works for both. Is this true?
TomWaltz
That's why.
Archicad 10 will run on a MacIntel machine but the Installer program does not.
If you have the PPC version running somewhere, you can copy if onto the MacIntel machine and it will run fine (just a little slower).
Yes, it's goofy.
You should be able to download the Intel version from:
http://tr.graphisoftus.com/downloads/DL's%20for%20GraphisoftUS/AC%2010%20stuff/Intel-based%20Mac/AC1...
Tom Waltz
Thank you so much. I'm downloading the install app now.
I Archicad 9 on MacbookPro renders invisible any item printed, downloaded or screen captured on the desktop. This is annoying one must make a search and click in the item than it appears. Apple is speechless
TomWaltz
Is that Desktop stored on your local machine or on a Network volume? I've seen that problem on networked systems before (with roaming profiles) but never a stand-alone machine.
Tom Waltz
the link you sent to install archicad 10 on my new mac book pro worked perfectly, just wish i wouldn't have forgotten my wibu key at work. guess i'll try it out tomorrow. thanks again for the assistance
