Learn more
Noel Cicek
Macbook Pro M4 Base model
Im considering buying the base Model Macbook Pro M4 with 16GB of RAM and 512GB SSD, does anyone have experience with archicad on this specific model. Will it run smoothly, also with heavy projects?
1 Reply 1
I am sure Archicad will run on an M4 as others are using them.
Just do a search for Macbook Pro M4 and you will find a few posts.
But if you are asking about heavy projects, I would not consider getting anything with base level specs.
Just look at the minimum specs that Graphisoft recommends, you will need much more memory for a start.
