2005-12-15 10:24 PM - last edited Wednesday by Molinda Prey
2005-12-15 10:28 PM
2005-12-15 10:43 PM
2005-12-16 04:32 PM
2005-12-16 05:10 PM
marta wrote:Photoshop Elements works quite well for simple texture editing and is a fraction of the cost of the full product (about $90 USD)
sorry. yes. do you have photoshop? there might be something else that works, but this is what i use? so, find the texture, change the color and then under options, attribute settings, materials, you have to create a new materials using that new colored texture.
2005-12-16 06:57 PM
Bob wrote:Check which material is applied. Edit that material, or define a new one.
I installed a roof with the surface material Roof standing seam 16". This look fine but I wanted a different color, so I went to the material menu and made a copy of the Roof standing seam 16", remamed it and change the color to what I wanted. I then edited the roof appling the new material. When I looked at it in 3d it's the same grey color of the original. What did I do wrong.
