Installation & update
Ongoing display issues with AC13
I'd love to know whether this is affecting other users - and how much? After a short while we are seeing corruption in the display- i.e. no click check on screen, and no rubber band line as the cursor is moved.
Requires a reboot to work again.
And that is with a relatively recent 9800GTX - ideas anyone?
FYI we have tried
- 2d hardware acceleration to 'off'
-running one monitor only
We have several users with this same issue.
The cards that are having the problem at the moment are GeForce 8800GT
and Quadro FX570.
I have tried installing the latest video drivers, but it normally make things worse, so I end up reverting back to an older driver.
I have found that sliding the hardware acceleration bar helps refresh the video card, but 30mins later the problem reappears.
Tech advice from GS Australia was to install the latest drivers - sadly sill not fixing problems!
My confidence in this program erodes a little every day...
