2019-10-15 04:57 PM
2019-10-15 05:00 PM
2019-10-30 04:16 PM
2019-10-31 02:34 AM
runxel wrote:
I also have some trouble with v23, which were not that present during beta.
I've downloaded this sample project from the Graphisoft page.
All views are slow, zooming beyond 200-300% is laggy as ####.
The plan is unusable – regenerating again and again. Overall this is the worst performance I had for years.
2019-11-04 08:30 AM
2019-11-26 10:17 PM
2019-12-04 01:12 PM
runxel wrote:Hi,
Zones seem to be problematic.
If I select them (even in an otherwise near empty project), it takes seconds until the info bar shows anything. With fills it's there in an instant.
Same with the PET pallet: takes ages until it shows up with zones.![]()
2020-01-22 11:40 PM
gpowless wrote:
I have found a number of performance issues with AC23 that wern't there in the RC version.
1. Adjusting heights or widths of complex profiles is incredibly slow. Selecting a node to stretch cause a spinning ball for 10-15 seconds each time. If I over shoot the mark I am attempting to adjust to the spinning ball reappears and takes another 10-15 seconds to respond.
2. Most profile offset modifiers can't be adjusted in 3D. Occassionaly they will adjust by small increments but most times selecting the adjustment bar does nothing.
2020-01-27 05:29 PM
Ghaleb wrote:Thanks for your attention
count the 'User Objects' and 'GDI Objects' columns
2020-02-05 11:59 AM
gpowless wrote:Hello Daniel,
3. When the trace reference is turned on in plan view and I switch to 3D view orbiting is slow for a short (20-30 seconds) period. Once it has (I assume) updated or completed the operation delaying the movement it appears to operate as normal.
I will keep adding to this thread as I find anything else....
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
