2004-10-27 12:21 AM - last edited Thursday by Molinda Prey
2004-11-01 08:00 PM
Geoff wrote:How is your Java?
Dude you've been busy on that hammock
2004-11-09 04:09 PM
2004-11-10 04:49 PM
gkmethy wrote:I'm not so sure. In the non-working installation the .xml and .xslt files are created as usual but the ShortcutLayout.htm file is not. But when I tried moving the XslTransformer.jar file from a working install to the no-working one it did not solve the problem. Furthermore the working install has now stopped working but I'm not sure exactly when. I think it was after a restart or log-out. All of this has occurred on one machine, at home. I am checking to see if a fresh install stays good at work. I'll let you know.
It seems that it it is not a java problem, since it works fine for you up till the XslTransformer.jar creates the ShortcutLayout.htm file, but the browser does not start up.
Try this. In terminal, type:This works fine.
touch test.htm
open test.htm
Does the test file open correctly? Is it Safari or something else?
2004-11-10 07:19 PM
2004-11-11 03:41 AM
2004-11-12 06:24 PM
2004-11-13 04:09 AM
2004-11-13 08:57 AM
Geoff wrote:mate - are you on the latest java update? are you repairing your permissions? it all worked OK here (before i had my archiCAD drought )
Sorry no miracle. Same sad fate. Weird thing is that it works for a while if I re-install ArchiCAD, then something poisons it.
2004-11-13 12:02 PM
~/archiben wrote:Sorry about the loss dude, very harsh.
it still sounds to me as though you're using an app (or an app/installer you've used) is preventing your access to the /tmp/ folders . . .I hear you but I can't track it down. Other apps, including ArchiCAD are successfully writing to that folder. The two other files, the ones created by ArchiCAD are delivered there without fail.
(just a thought: do you have any scheduled/automatic backup software kicking in at any time?)Yes, I have an app called ChronoSync performing back-ups to a FireWire hard drive. Could that be it? How would that screw things up?
2004-11-15 10:42 AM
