Problem installing Archicad 18 educational version Mac
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2015-09-13 11:02 AM - last edited on ā2024-03-26 02:25 PM by Aruzhan Ilaikova
ā2015-09-13
11:02 AM
Installer says "not enough disc space to install archicad 18" but there should be plenty! Installer doesn't allow to change the install location. Computer gets stuck if i try. But i read somewhere that you can't change the application install location at all with macbook pro..Can someone help?
Labels:
- Labels:
Install & Update
macOS
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2015-09-14 10:35 PM
ā2015-09-14
10:35 PM
If you choose the Custom Install option during installation you can specify a new location for the installation.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2015-09-15 09:07 AM
ā2015-09-15
09:07 AM
It doesn't give me a custom install option, and i've tried every way possible like i said earlier, in the same window the installer says not enough disk space, there is a browse button which gives the opportunity to choose installation location, but it jams the computer if click it. So i think i should somehow change the location before installing, but i don't know how, or is it even possible in macbook. My friend has the exactly same laptop, with even less disc space than mine, and there was no problem when i installed the archicad there. And it works fine. I really don't know what's the problem.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2015-09-15 12:58 PM
ā2015-09-15
12:58 PM
Could this be some kind of a permission issue, where a folder on the path to the installation folder does not give you enough permissions?
Unfortunately, I am not familiar with the Mac, so hopefully someone else also has an idea.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2015-09-15 01:16 PM
ā2015-09-15
01:16 PM
Might be, but i haven't got a clue what to do about it thank you anyway!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2015-09-15 01:18 PM
ā2015-09-15
01:18 PM
You should also check if your computer meets all of the system requirements for ARCHICAD:
http://www.graphisoft.com/support/system_requirements/AC18/
Plus, there is an installation troubleshooting guide, hopefully you will find the cause in this article:
http://helpcenter.graphisoft.com/troubleshooting/setup/archicad-18-install-and-startup-troubleshooti...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2015-10-06 08:35 PM
ā2015-10-06
08:35 PM
I had the same problem. I was running OSX Yosemite 10.10. But when I upgraded to 10.10.5 I got to change the installation folder, but I had no space again. So I installed it on a portable flash drive and relocated the folder to Mac and it works.
What Mac and OS are you using?
