Problem object selection
When selecting an object, nodes that are outside the contour of the object are displayed. How to solve a problem. Thanks
4 Replies 4
Hello exprofeso,
Did you try this ?
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Is your model very far from the Origin? Is that a Column element that is selected?
(FYI: The various geometries you create are called "Elements" in Archicad. "Object" is a specific element type in Archicad, it is a general GDL-based element type, created with the Object Tool.)
Yes it is a selected column element
How far is your model from the Project Origin?
This kind of display inaccuracy usually occurs when the model is very far from the Project Origin.
