Problem when using XP-64Bit
Hello my friends,
I have ArchiCad 11, I got a new computer with Windows XP 64-Bit.
The Problem is that I cant see the names of the floors and the elevations in my language while the other things that I write in my language are working well.
Please take a look at the attached file if you dont understand the problem.
Thanks,
Adar
3 Replies 3
As a first step, make sure you have the latest update of the version available.
The Help\Check for Updates menu will do it for you.
Let us see if that handles it.
You could use slanted Walls and place Window holes in them or cut those holes using Solid Element Operations.
You could create the shape of the hole in the Profile Manager, assign that profile to a Beam, place te Beam with the Profile and intersect the Wall with it, then subtract the Beam from the Wall.
It may also be possible to create on such Wall using the Curtain Wall Tool.
Yet another option is to buy and use the excellent Add-On called Objective:
http://archicad-talk.graphisoft.com/viewtopic.php?p=150201#150201
JEREMIAHRICKY,
There are a couple of things I want to tell you:
1. You have posted a completely irrelevant post into this thread.
2. You have posted a completely irrelevant post in another thread asking the same question. I deleted that post.
3. You started a new thread and asked the same question again. For the title of the thread you have used the name of our Director of Global Marketing. I have deleted that thread too.
4. You are using all capitals in all your posts. This in internet forums is considered shouting and very impolite.
So, stop posting irrelevant multiple posts using all capitals. This is a voluntary forum. If you get no reply to your question, no one is to blame. No one is obligated to answer to anybody and they will not answer you just because you are loud enough or aggressive enough. On the contrary, you can get banned in no time.
There are many free materials on the web.
One of them is at:
http://www.graphisoft.com/products/archicad/training_guides/
You can download hours and hours of free training videos to learn from. Even if you cannot hear the sound, you can look at the movies and read the PDF files which gives you a lot of information.
There are also many videos on YouTube for you to watch.
Also there are many articles on ArchiCAD on the web.
Plus, you have the Help files on your computer.
So, you have a lot of stuff to choose from.
