Installation & update
Problem with Calibri font
Does anyone else out there use the Calibri font.
We are having problems with certain letter combinations in lower case only not printing in the PDF.
They are fine on screen in Archicad and the layout book.
Just a problem when published or printed to PDF - even with other PDF converters.
Only happens in version 11 & 12.
Version 10 is fine.
See the attached image.
Seems that "ft" and some other letter combinations do not print - they appear as a square with a question mark in it.
Would someone else please test this for me.
In particular on a Windows XP machine.
Thank you.
undefined
15 REPLIES 15
Thomas Holm
Works fine here on Mac AC12.
I think it's an issue with your copy of this particular font. The letter combinations are "ligatures" (combinations where certain characters overprint more or less, horizontally).
If I remember correctly, it's a Microsoft font, installed with MS Office. Try thrashing the font and then re-install MSOffice! And then restart. If necessary you may have to upgrade Office or search the Net for a newer version of the font.
Link
I'm currently building a template for a client who wants to use Cailibri as the main font, and can confirm the same problem on AC12, Vista.
I think Thomas is right about the overlap because inserting even the tiniest space (eg. a space between f and t with a height of just 0.1mm) will get rid of the problem.
Annoying workaround, but a workaround, nonetheless.
Link.
Thomas Holm
Link wrote:
...inserting even the tiniest space (eg. a space between f and t with a height of just 0.1mm) will get rid of the problem.
It's of course possible that there is a bug in the font that surfaces only when it's PDFed or printed. I wouldn't be surprised if the font prints all right on cheap inkjets that don't use PDF or PostScript for printing. Adobe owns both PDF and PostScript, and Microsoft isn't too fond of Adobe, and may be a little sloppy in bug-testing those options.
Thanks for confirming this.
It does seem to be a problem with the text spacing.
I set the spacing factor to 200% and the ft stayed stuck together.
Change the font and they spread apart.
Now do you think I will have any luck in getting Microsoft to fix the font?
Greg Kmethy
Graphisoft Alumni
This is a known issue with font types that use ligature - when two characters merge for better readability. http://en.wikipedia.org/wiki/Typographic_ligature The "Calibri" and "Symbol" fonts use ligature.
The problem is in the font, but the manufacturer of the PDF engine that we license promised a workaround in one of their updates. So we might be able to fix this at a later time, if the Font does not get fixed.
It is not possible to turn off ligature, but we found that on Windows XP it only occurs when asian fonts are enabled (Control Panel -> Regional and Language Options -> Languages -> Install files for East Asian languages)
We found that disabling this option turns off ligature in Calibri font, so that is a workaround on XP.
Gergely Kmethy
Thank you Gergely,
That seems to work quite well.
It's 2014 -- and v17 of AC -- and this problem with the Calibri font still exists, as I've just found out.
I've substituted a similar style of font, "Aller", which is available on a free license, from www.fontsquirrel.com/fonts/Aller
And yes, it's a PITA not having a global search & replace function.
It appears to work well upon publishing to PDF, unlike Calibri.
At the very least, ArchiCAD should consult a list of bad fonts, and warn the user upon selection if the chosen font is bad for PDF output.
Upon release of AC 18, it seems that my font of choice is no longer supported. I have used Neutraface for almost ten years and now all type in this font has vanished from my publisher pdfs. It is REALLY annoying to have to reformat numerous projects/templates to a different font!
Eduardo Rolon
Same thing here with 'Geometric" and "Neuzit" finally gave up and I am using only system fonts.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
