Problems with Shift and option key on Snow Leopard.
I just upgraded to 10.6.2 and have a problem where the option key is not recognized. Even when trying to option click a wall to pick up attributes.
Shift Key will not constrain walls either.
I have tried a NEW and RESET ALL as well
Any help solving the problem would be very helpful! as it is pretty much useless to work without these keys functioning.
It is possible this started happening with the latest update. I can't recall if I used archicad after the snow leopard update but before the last ArchiCAD hotfix.
8 REPLIES 8
Eduardo Rolon
I have been running 10.6.2 without problems since it was released. Do you have any keyboard utilities installed? I know that Steermouse has some problems with wireless mice, if you turn off your mouse AC will not be recognize pressing the wheel as pan. Also you might try unplugging your keyboard and replug it, my MacPro sometimes forgets that it has a keyboard attached.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Rod Jurich
Daniel, running SL since it's release without issue all versions of 13.
You wouldn't by chance have grid snap activated.
I have disabled S shortcut
Rod Jurich
No utilities for keyboard. And, it was working fine at least before the recent hotfix. No, snap grid is not the problem either It is strange that both shift and option are absent. They both work for other shortcuts, just not the important directional constraint or the Pick up Attributes. Therefore, I fdon't think any other software is disabling the keys in anyway...
Daniel,
This issue seems rare enough that I wonder if you might not try (a) creating another account on your machine and seeing if Opt works there - suggesting that some login item is conflicting with 10.6.2 or (b) if that doesn't work, restart in Safe mode to disable all extensions and see what happens...
Pretty weird.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thanks Karl,
Seems close....I have a guest account that I switched over to and the keys work fin there. Do you know of any preference files that might need to be deleted to getting it going again?
I did have ALL other applications closed ,but I turned on Activity Monitor and noticed that I have a hidden Process/Application running for Quicken called Quicken Scheduler that I forced quit and my keys immediately came back without even having to restart ArchiCAD. That was pure luck finding that one.
Cool. Glad you found it. Not surprised it was Quicken-related. Intuit's software is the buggiest of any manufacturer I've dealt with. (Stay away from QuickBooks for Mac 2010 for now, for example.)
tsturm
see post "Option and Shift Key not working" for the solution to this problem
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
