ā2017-03-21 10:19 AM
<reporterror>ODB assertion failed at /Volumes/LaCie/VMWD/Build/Sources/ObjectDatabase/ObjectDatabaseDll/IndexQuery/ODBTypeIndex.cpp 109</reporterror>
error code: -2130575345 description: isolated state read error on VirtSy 9F0F1F3F-6AB4-A2C9-18F8-C332A38989D3</reporterror>ase/ObjectDatabaseDll/DifferenceManagement/ODBDifferenceMerge.cpp 718
</reporterror>/LaCie/VMWD/Build/Sources/ACPM/ArchiCAD/ACPProject/ACPTWProcessHandlerImp.cpp, line: 4704.E, err = -2130575345, severity: Error,
<reporterror>ODB: logic error encountered</reporterror>
<reporterror>OSUtil::TerminateProgram called (A load operation failed in FileDatabase) ! - /Volumes/LaCie/VMWD/Build/Sources/ACPM/ArchiCAD/ACPProject/ACPDatabaseErrorHandler.cpp(143)</reporterror>
links: </reporterror>ctModificationNotificationForRingsame Idon failed at /Volumes/LaCie/VMWD/Build/Sources/ObjectDatabase/ObjectDatabaseDll/ODBIdSpace.cpp 735
error code: 13</reporterror>].rpt:<reporterror>ODB assertion failed at /Volumes/LaCie/VMWD/Build/Sources/ObjectDatabase/ObjectDatabaseDll/RandomObjectFile/ODBRandomObjectFile.cpp 3565
Seems like there's some corruption going on in the file's internal database? I don't really know, but I hope someone does! ā2017-03-21 11:37 AM
Kieran wrote:Could this issue with a Win 10 security update be related?
As it stands I can open the project, it seems to work fine, open and repair says there's nothing wrong but after a few house of work, it crashes and can't be re-opened. The crash generally occurs when we try to save the project, of course.....
We use ArchiCAD 20 5025 mainly on Macs (10.11) but with one Windows 10 machine.
ā2017-03-21 11:49 AM
Ralph wrote:Strangely it hasn't crashed on the windows machine, only on Macs. I've uninstalled that update as a precaution, thanks.Kieran wrote:Could this issue with a Win 10 security update be related?
Ralph wrote:Sadly not - It's happened as a shared project on the server, then as a solo project on 2 different client machines.
Otherwise, is there any hardware that is common to all the crashes, e.g. a common server? If so, try working apart from that hardware and see if the crash occurs again. RAM or storage failures are common culprits for corruption and crashing, so I'd try to eliminate that possibility first.
