Installation & update
Ram Samsung is better for archicad 21 (windows 10) then Ram Kingston or other..?
Hi all! Is it true, that the Ram DDR3 Samsung is better, i mean work more fast for archicad 21 (windows 10) then Ram Kingston or other with the same frequency ?
5 REPLIES 5
Lingwisyer
Guru
If it has the same tech specs, I would say it should be the same. The difference being better quality being more reliable and / or easier to manufacture.
https://forums.tomshardware.com/threads/what-is-the-best-ram-manufacturer.422459/
https://www.ranker.com/list/the-best-dram-manufacturers/computer-hardware
You should probably be looking at other components if you are looking at performance gains, unless you are "min-maxing" at which point you would not be asking this question, especially here.
Ling.
AC22-28 AUS 3001Help Those Help You - Add a Signature
Thank's for the answer. I think the same, no mattr which brand use when frequency of the ram the same..
Erwin Edel
Just make sure to check what your motherboard takes.
We accidentally ordered non-ECC RAM once for our HP workstations and they didn't take the cheap 'gamer hyper Xtreme racing car red' RAM, only ECC.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Lingwisyer
Guru
My computer also only takes ECC RAM. Which is sad as it is super expensive to upgrade yet I do not get any benefit from the ECC functions... Pay more for lower performance... Dual Xeons were awesome though, but they are getting dated...
Ling.
Erwin Edel
Yeah, running Xeon E5-1620 v2 @ 3.70GHz here, still works fine some 10 years on.
Luckily it has a lot of memory bays, so we just bought I think a lot of 2 GB ECC to make it to 16 GB (up from 8 GB), which still holds up fine.
www.leloup.nl
Windows 10 Pro
