!Restored: ArchiCAD 8 new user question on Step Files Folder
I know this is qoing to be old hat to all of you, but I just installed Arch8 and started to go through the tutorial but can not find the Step files folder.
I did a search of my C:drive and then searched the CD no files by the name of Step-01.pln Aren't these files suppose to load with the installation? Went to this link http://www.graphisoft.com/ftp/ac8step/eng_imp/stepby.htm
only to find that it is no longer a good link.
Any info on how to load or how to find these tutorial files?
Any help with this old version would be very much appreciated.
4 Replies 4
Eduardo Rolon
Check in the archicad folder in program files, I think it was there.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
TomWaltz
I think the Step-by-Step was on a separate disk, not the install disk.
Tom Waltz
Djordje
It was on a separate disk.
Talk to your local reseller, he might have some boxes collecting dust somewhere ... and get 8.1 while you are at it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Just want to thank everyone that responded to my initial problem. It was actually on the original ArchiCAD CD, I only had the one disc. The problem was I had to run one setup for ArchiCAD and a second setup for the tutorial files.
Thanks again.
