2008-05-13 11:19 AM
2008-05-13 03:25 PM
MrFixit wrote:There's your problem right there. I think the patent has issues related to processor identity confusion. He needs to decide whether he is a PPC or really an x86 at his core. Thorazine may help.
Patient:
Factory new MacPro G5 Dual Quad Xenon 2,8GHz w/ dual ATI X2600s'. 4Gb RAM.
2008-05-13 03:43 PM
2008-05-13 06:50 PM
2008-05-13 08:11 PM
MrFixit wrote:My understanding is that the PPC version is icluded but as Karl says, the installer should load the proper version.
Was "PPC" version perhaps at sometime included in the deliverd medium?
MrFixit wrote:All the usual suspects: too many trees or other poly-heavy objects will bring 3D to a crawl. Excessive and/or complex SEOs will do the same. Lots of placed rasters or huge placed drawings can kill 2D. The total file size is not always a good indicator of expected performance. Downloading and using the poly count goodie will give you some feedback on the complexity of the file. At least on the 3D side.
What are these other possible issues?
2008-05-14 04:20 AM
Chazz wrote:IS there a way to quickly check which is installed?
Chazz wrote:The above lends me to belive that this may be the case. Tho my knowlage of AC is too limited make this judgment call of the bat. Hence me asking here 😃
That hardware should give more than acceptable performance. I'm working on a 108 GB file on less than half as much hardware and I'm doing OK.
Are you sure this isn't a PEBCAK issue?
2008-05-14 04:28 AM
another Moderator
2008-05-14 06:00 AM
ejrolon wrote:Good one!
...if it says PowerPC next to AC then you installed the wrong one.
2008-05-14 04:07 PM
