!Restored: problem with archicad 10 and the cpu usage
Hello to everyone, i want to know if someone has this problem. I started to work with ArchiCAD 10, and everything is fine, but in some moment the system starts to work very very slow, and when i check the cpu usage all the four processor are 100% usage, even if i quit the archicad the problem persist, and this happen since i installed the new version. any knows why this happen
6 Replies 6
David Pacifico
You should describe your system in more detail.
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
My system is an alienware, with two procesors of 3.6 x64 with ht, 3G of ram, an nvidia quadro fx 540, the hard drive is a 36 gb raptor of 10k rpm, and the monitor is a cinema display 23"
Djordje
Put this into the signature; specify the OS (XP, which SP) too.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Rick Thompson
This is a screen shot of some weirdness I had reported to GS. Under the navigator you can see what is running. Sometimes, but not always I appears many copys are running, which could obviously eat processors. I don't know if that's you case or not, but something you might look at when you notice it. The only way I found to "fix" it is to close and reopen AC.
The screen shot shows several projects running, and closing and then reopening the project increases the "running" projects multi-fold, not just 1 additional times. I have seen it with 30 or moire "running".
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Rick Thompson
This screen shot shows what can happen.
Rick Thompson
Mac Sonoma AC 26
I found a solution to the problem that i have, i dont know if its the best , but for now works, when the cpu usage increase to the 100%, i check for the processes, and after a los of trial and error, i found that clossing a particulary process the cpu usage goes to a normal level of 2 or 7%, the process have this name "40exmodul32.exe" sometimes the 40 number change, 45, 17, etc.
