Running AC 12 with integrated graphic card?
Would be a problem, running AC 12 with integrated, 256 mb graphic card? Thx.
9 REPLIES 9
I know people who have integrated graphics cards in their desktop machines and they are running ArchiCAD fine.
The only question is: what happens if you have a larger project with a large 3D model (many polygons in 3D). Will the OpenGL performance of the graphics card be enough to handle it.
That is a good question.
Of course if you are not working with high 3D polygon count projects than I believe you should not have a slowness problem in 3D.
Anyone know about integrated graphic card Nvidia 9400 in new iMacs?
Do I run properly AC12 and Artlantis Studio2 with large detailed models, in
a Core2Duo 2.66 with 2gb 1.066mhz ram?
Thanks in advance.
I tryed it with AC11 - not good!
Then I bought NVidia GeForce 9600 GT - much better!
In general:
Large and/or highly detailed models call for a pro machine w/dedicated video, though high end cards (such as Quadro) don't seem to be worth the extra $-£-€.
Small models can run on just about anything that's reasonably new, with the possible exception of really low end Windows machines.
aahatimo
is this still true w/ the new mbp?
as i under stand it the 15" model uses both the nvidia integrated 9400m along w/ the gt 9600m gt.
http://www.apple.com/macbookpro/graphics.html
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Are there any stats or benchmark tests that show AC uses the NVIDIA 9600M to make a difference in speed over the NVIDIA 9400M?
I am in the market for a new macbook pro 15.4" 2.53ghz w/NVIDIA 9400M or 2.66ghz w/NVIDIA 9600M.
Check out this table:
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_Graphics_Processing_Units#GeForce_9M_.289xxxM.29_s...
Look under the GFLOPS (gigaflops - billion floating point operations per second)
Looks like the 9600M GT card (what the MacBook Pro has) is more than twice as fast as the 9400M (115 vs 53). This mostly counts in 2D and 3D navigation.
Looks like they can also have more memory. I would probably go with 512 MB of GPU memory just to be still good 2-3 years from now.
Matthew wrote:
In general:
I would have to disagree on this. I was using a GeForce 7800GTX card before I upgraded to a new desktop machine. I spec'd a QuadroFX 1700. It's not a lot of money (two years ago I paid $250), and the 3D navigation AND 2D navigation and overall stability is MUCH improved.
To confuse things a bit, though, I would also like to add that I am in the laptop market now, and don't anticipate buying a workstation card. Right now I'm looking at an ASUS N71 series with the Radeon HD5870 card.
After reading this:
http://archicadwiki.com/Video%20Cards%20for%20ArchiCAD%2013
I'm back on the QuadroFX bandwagon....
