Installation & update
STAIRS TURNING IN PLOTMAKER
I'm using Archicad 9 and I seem to be having a problem with my stairs when importing the section view into Plotmaker - the stairs turn through 90 degrees... so you see them in elevation rather than section!!!
I have deleted them, redefined them in the model, resave and re-imported them, but with no joy... they still turn themselves around!!!
I know I can copy the section and create a 2D drawing, but won't to do this only as a final option, as if I have to make future changes it's a bit of a pain to then have to do extra work in the 2D section... can anyone suggest what I can do...?
1 REPLY 1
Can you save a PMK file from AC9 and import the PMKfile in PM9? That will be a drawing, it will not move or go anywhere.
