2020-10-09 10:56 AM
2020-10-12 03:33 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-05-26 09:01 PM
2021-05-27 09:27 AM
Minh Nguyen
GRAPHISOFT
2022-08-03 02:59 PM
I also get this message in AC24, and just saw this message again in AC26, while working on the template.
Has there been any resolving of this issue?
2022-11-28 06:15 AM - last edited on 2022-11-29 03:26 PM by Laszlo Nagy
I have this problem:
EcoDesigner STAR license activation failed.
Protection Error Code: 200
EcoDesigner STAR Add-On functions will be disabled.
You can continue using Archicad without the features of EcoDesigner STAR.
Number of processor cores : 16
Building Material not found
at line 107 in the 3D script of file Internal Gutter #2028.gsm. (OBJ-0003 | 17B0DFFC-936E-4754-9F2C-D466D03B57A5)
Document name : Bibaringa Consent
Processed : 13 walls 31 objects 19 columns 0 beams
6 slabs 0 meshes 0 roofs 0 morphs
railing: 0 handrails 0 panels 156 posts 312 rails 108 toprails 300 balusters 240 innerposts
48 toprailends 0 handrailends 0 railends 0 toprailconnections 0 handrailconnections 0 railconnections 0 railingfinishgdlobjects
Elapsed time : 1 seconds
Conversion of Objects to MEP elements begin.
Statistics:
Checked elements: 4742.
Objects without MEP elements removed: 0/0.
MEP compatible elements converted: 0/0.
Inconsistent elements: 0/0.
Derived data updated: 0/0.
MEP structure created: 0/0.
Segments with unconnected holes: 0/0.
Repair function #1: 0.
Converted to Objects: 0/0
Conversion of Objects to MEP elements end.
Projection : Front view
Elapsed time : 0 seconds
2022-11-28 06:59 AM
This is a report telling you what the problems are.
You have a file that seems to have been worked on with EcoDesigner Star active.
You don't have it active so the add-on functions for it have been disabled.
If you have an EcoDesigner Star license you can activate it.
If not, there is not much you can do, except for maybe use version 26 which I believe has ED* built in now.
You also have an internal gutter object that has a missing building material.
Find that object (ID=OBJ-0003) and fix it and this message will disappear.
The rest just seems to be regular report information.
2022-12-15 07:32 AM - edited 2022-12-15 07:36 AM
Currently working through our Archicad 26 template, and having the same issue as listed above, so 26 doesnt clear this error.
2022-12-15 07:40 AM
What error is that?
I don't think the report clears itself so it may be the same message over and over.
You can always select the text and delete and then see what comes back.
Barry
2022-12-15 07:51 AM - edited 2022-12-15 07:52 AM
Sorry barry was refering to the EcoDesigner STAR active error, i did attempt to clear that error report from the list, but upon saving and reopening, the error returned. The file itself is brought forward from earlier versions of Archicad, im guessing this could cause the issue. Currently trying to plan out transferring everything into a fresh AC26 file. just againt time at the moment. How ever, a fresh AC 26 template file still pops up with the EcoDesigner STAR error for missing license.
