fabioferrini
Space Mouse and AC26
Hi all,
my 3DConnexion space mouse does not work with archicad built 26 5002 full ITA, but works fine with AC25.
Any suggestion? Thanks
Fabio
3DConnexion driver 10.8.0 iMac (Retina 5K, 27-inch, Late 2014), 4 GHz Intel Core i7 quad-core,
AMD Radeon R9 M295X 4 GB
2 Replies 2
Related topics, with possible solution:
https://community.graphisoft.com/t5/Installation-update/Space-Mouse-is-not-working-with-Archicad-26/...
https://community.graphisoft.com/t5/Installation-update/Compatible-mouse-with-Archicad-26/td-p/35281...
Jeff G
I use a 3DConnexion SpaceNavigator on a Mac (running macOS Ventura) with Archicad 26 USA Full. I experienced issues (I don't recall what they were exactly) with the latest 3DConnexion drivers, so I uninstalled the new drivers and installed version 10.7 and things are now working well.  I'd suggest you try the same. Version 10.7 can be downloaded from here: https://3dconnexion.com/us/archived-drivers/?fwp_drivers_os=macos-12
iMac 27 (2020) 3.8 GHz Core i7; 128 GB RAM; Radeon Pro 5700 XT 16 GB GPU (macOS Sequoia)
MacBook Pro M1 Max; 64 GB RAM; 10CPU/32GPU cores (macOS Sequoia)
ArchiCAD 30/29/28/27 USA Full (back when Full used to mean Full) (latest builds). User since AC12 (2008).
