2005-07-11 05:11 AM
2005-07-28 10:24 PM
junior wrote:Install without the key. Reboot. Insert the key. Choose automatic installation. That's it.
I became familiar with starting the wibu key in the mac, thanks again guys. How do I start the wibu key when my environment is windows pc (winXP) ??? I've already installed the latest wibu driver for windows from graphisoft..
2005-07-29 03:54 AM
Djordje wrote:Thanks Djordje! I just want to make sure though, when you mentioned "Install without the key."... did you mean install "ArchiCAD" without the key? Thanks again.
2005-07-29 08:12 AM
junior wrote:Yep. If the driver is not installed previous to the key being inserted, XP will look for nonexistent drivers. So, install ArchiCAD - and the drivers - first, then reboot (just in case) and insert the key.Djordje wrote:Thanks Djordje! I just want to make sure though, when you mentioned "Install without the key."... did you mean install "ArchiCAD" without the key? Thanks again.
