SOLVED!
Cannot use objects in goodies 27 (roof accesory object)
user-jose
I have tried all the latest suggestions to use roof accessories: I uninstalled archicad 27  then I reinstalled it. Before starting archicad, I Installed goodies 27. Started archicad 27. Although the design extra tab/accessories/roof accessories appear correctly  on the design menu,  the roof accessory object is not loaded.
The roof accessories library does not appear
I have tried to load these library parts using Library manager without success. Program informs that these library parts are already loaded. Please help
1 ACCEPTED SOLUTION
Solution
Thanks Ill try that
2 REPLIES 2
Lee Hankins
There should be an 'Accessories Library 27' that you need to load, not the 'Goodies' folder. I believe you download the Accessories Library separately. The library should have installed as part of the Goodies Suite installation. On a Mac it is located in the program folder of Archicad 27, I assume this would be the same for windows.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Solution
Thanks Ill try that
Setup info provided by author
