2024-06-05 01:06 PM - last edited on 2024-06-11 11:59 PM by Laszlo Nagy
I have tried all the latest suggestions to use roof accessories: I uninstalled archicad 27 then I reinstalled it. Before starting archicad, I Installed goodies 27. Started archicad 27. Although the design extra tab/accessories/roof accessories appear correctly on the design menu, the roof accessory object is not loaded.
The roof accessories library does not appear
I have tried to load these library parts using Library manager without success. Program informs that these library parts are already loaded. Please help
Solved! Go to Solution.
2024-06-06 03:50 AM
2024-06-05 02:05 PM
There should be an 'Accessories Library 27' that you need to load, not the 'Goodies' folder. I believe you download the Accessories Library separately. The library should have installed as part of the Goodies Suite installation. On a Mac it is located in the program folder of Archicad 27, I assume this would be the same for windows.
2024-06-06 03:50 AM
Thanks Ill try that
