2025-04-12 09:58 PM - edited 2025-04-13 03:12 AM
How can I import my work environment (as set up in many generations of Intel Archicad) into Silicon Archicad? Or do I have to redo it piece by piece?
Operating system used: Mac Apple Silicon 15.4 Sequoia
Solved! Go to Solution.
2025-04-13 02:18 PM
I used the same custom Work Environment on both chips without any issue or changes. Under Work Environment select your Work Environment Profile, then click the Export button to save your WE for Import on another computer. I don't recall any problems switching from Intel to Silicon with ArchiCAD.
2025-04-13 06:26 AM
I have never tried this but I would export your Work Environment from your old Intel machine and then try to import it to the new Silicon one.
I am not sure how it will handle keyboard shortcuts or folder paths as they will be different.
But all you can do is try.
Or maybe you can just export/import just the menus and toolbars (they should be the same).
And worry about the shortcuts separately.
Worst case scenario, you will have to recreate WE from scratch.
2025-04-13 02:18 PM
2025-04-14 03:04 AM
Sorry, I think you mean MAC Intel to MAC Silicon?
If so there should be no issues.
I was thinking you were meaning Windows Intel to Mac Silicon.
2025-04-14 04:19 PM
I was trying to do it the same way you can import Attributes. I missed the export step. Thanks.
