Wall showing thru door in plan
The file created in an earlier version of archicad (v10) and then I think v(23) now converted to 24 is doing some funny things with doors. some doors don't show well in plan. The wall runs right through. Any ideas how to fix this? Thanks, Mark
2 Replies 2
Is it possible that there are two Walls there? The Door was placed into one of them and it would show correctly, but the other Wall is also there in the same place, causing this display issue. Could this be the reason?
Guru
Check your Renovation Filter?
