Warning message
Hello, AC 12
When i try to run archicad i get this message
warning: cannot create temporary document
When I tried to clean AC temporary file folder i found this file
@Lock.T
..and this empty folder
LCFUnZip
I dont no in what direction I should look to solve the problem.
14 Replies 14
Kudos Dave,
I knew there was a simple solution.
Didn't really want to mess with regedit
Tom
Roopa A
Hi ,
My client is also having the error message like cannot save temporary document.
They were using AC 18, in laptop with configuration of,
Windows 10,Core i7, 8GB RAM. with NVIDIA GeForce.
We uninstalled and re-installed the software. Still it is showing the same.
What would the problem.
Roopa A S
designtech_julius
Lifesaver, thank you!
Delete Autosave Folders in the following location(s):
  • WIN: C:\Users\<user>\Graphisoft\AutoSave-<version>-<number of open projects>
  • MAC: System drive/Users/<user>/Library/Application Support/Graphisoft/AutoSave-<version>-<number of open projects>
AC 11-25
WIN 10 - Intel i7 - RTX 2080
MAC - MBP M1 Max
Brano
I do have the same problem, but If I delete autosave directory from that day, AC25 will firstly open succesfully, but on second start it fails and error message still remain: Cannot Create Temporary Documents
Do you have any suggestions pls?
Brano
Problem seems to be solved when I have deleted all autosave directories not only from that day when problem starts.
I hope it will remains working ...
