What hardware makes Archicad go faster?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-07-20 01:36 AM
The new 15" MacBook Pro has options for:
Processors: Both are 8-core i9, one is 2.3 Ghz the other is 2.4 Ghz +$200
Memory: 16 or 32 GB +$400
Graphic Cards: Radon Pro (each with 4GB memory) 560X, Vega 16 +$250, Vega 20 +$350
All HD's are SSD
If I only have $600 more to upgrade the the 15 inch MacBook Pro's basic offering, which of the features above will have the most influence on keeping Archicad running fast?
In other words, if 16 GB of ram is more than enough, buying 32GB will not improve anything, Right?
Or while the higher priced graphic cards improve game play, does Archicad tap into their power to make it worth spending an extra $350?
The speed upgrade from 2.3 to 2.4 Ghz seems rather insignificant from my lack of knowledge. Is it insignificant? Is it worth the upgrade?
How does Archicad use these?
I would think that a Windows tech guru could also answer these questions too.
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-20 05:00 PM
Todd -
I currently use a 2015 Imac with and 1TB SSD and 32GB of RAM. Running ArchiCAD 22 works plently fast even with complex models. But that is not the whole picture.
The minute I try to run any rendering from within AC or export out to for an Artlantis or TwinMotion render, my iMac falls down. It has nothing to do with the CPU, rather the GPU is the week link in the iMac.
So the big question is, are you going to just work in ArchiCAD, a base
MARIANI design studio, PLLC
Architecture / Architectural Photography
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-20 11:50 PM
For me, the order of priority of components are:
1. RAM
2. CPU
3. SSD (NMVe)
4. GPU
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-21 05:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-21 10:27 PM
The ARCHICAD 22 System Requirements page at:
says:
Graphics card: Dedicated OpenGL 3.3 compatible graphics card with on board memory of 1024 MB or more is recommended to fully exploit hardware acceleration capabilities. You can find a list of recommended graphics cards at: http://www.graphisoft.com/videocards
According to Apple, this card supports OpenGL 4.1, so it should be fine in that regard:
https://support.apple.com/en-il/HT202823
The 560x is probably strong enough, GPUs nowadays are very powerful, even those which are not the top-of-the-line.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-22 03:12 AM
Also, do you do much multi-threaded work? Is there no option for few cores at a substantially higher clock?
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-22 01:20 PM
I've bought 3 iMacs over there years and I found there certainly was a sweet spot where the extra investment still made sense in keeping your machine viable for many years. There also was a point where your really overpaying to get the 'latest and greatest'. 16 GB RAM seems ok for our rendering needs, but has been a staple for many years, so for future proving, I'd say go for at least 32 GB. SSD is a must. Any halfway decent dedicated GPU should be enough for ArchiCAD. You might need something a bit better if they ever do get BIMx running nicely on desktops.
Apple hardware is pricy, but generally seems to last and is well supported by the OS for years, at least I've not had any problems with those iMacs and had each for a good 4-5 years and they held value for trading in when I upgraded (because apple fanboys!).
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-22 03:19 PM
Erwin wrote:
...for future proofing, I'd say go for at least 32 GB. SSD is a must. Any halfway decent dedicated GPU should be enough for ArchiCAD...
My opinion exactly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-22 05:25 PM
The GPUs and now eGPU availability on newer Macs since High Sierra came out, is another issue to consider.
The people at Epic / TwinMotion, seem to point to getting the FASTEST possible AMD GPU cards possible for Mac users, as nvidia no longer supported by Apple.....not now anyway.
So its not clear to me if the goal is to produce the fastest renderings with TwinMotion, models produced in ArchiCAD, if it makes more sense to spec the fastest GPU Apple offers in their MBP or iMacs or if it makes sense to get the lowest grade GPU from Apple then add an eGPU which gives you the flexibility to move it to different machines or just keep it in your office and use the one onboard GPU with the MBP when you are on the road?
Mac OSX 13.1
AC 24 / 25 / 26
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-07-23 05:21 AM
He said he does not want to use it for Artlantis or Twinmotion:
So if I have no intention of using Artlantis or TwinMotion for AC 22 or 23, I should be fine with the basic option currently being offered for the 15" MacBook Pro?
