ADALBERT - et al.
Here is the Graphisoft response:
The workaround until WIBU fixes this problem is to install the respective driver for the version of AC you want to run.
For AC9, use the 5.0.1 wibu driver for OSX. For AC10, use the Intel specific 5.10.502 wibu driver version.
I have a folder containing both of these drivers, and simply install the desired driver (overwriting the previous one) when I need to use the other AC version.
You can not run both version simultaneously on Mactel.
I have uploaded these files to our ftp.graphisoftus.com ftp site under:
DL's/un-filed DL's/WIBU/
WibuKey_AC9.dmg.zip and WkRuntimeUser_5.10.502.dmg.zip
MY RESPONSE, simply stated:
Wibu driver 5.0.1 will authentic all versions of ArchiCAD running the G5, G4, & G3 processor.
Wibu driver 5.10b will authentic ONLY ArchiCAD 10 running the G5, G4, & G3 processor, or a Mactel.
My only complaint now is why Graphisoft can't get the versions staight. For the Graphisoft web site it is Wibu version 5.10b, for Graphisoft tech support it is Wibu version 5.10.502.
No wonder I keep turning in circles
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
