I am using Archicad 9 on a PC with Windows XP pro. During the past few days, every time I open any project/drawing I have to resize my working window as it comes in at about 70% of the size, compared to when it was last saved. It is begining to drive mad having to drag the handles to resize every time I open, I have no idea why this is happening, everything seems to be working ok on my system. Any suggestions out there?
Thank you for the advise Lukas, I have gone into OPTIONS, WORK ENVIRONMENT, but the dialogue box does not show SET UP WORK ENVIRONMENT, and it does not have a drop down box with Last Profile Used, all it shows is Expert 9, Novice 9 or Standard 9.
When you start AC, before you even get all your tools and libraries loaded, you get a dialog box where you get to choose which file to open. That's where you chose to open the selected file with the last profile used.(there is a drop down menu at the bottom of this dialog box) If the last time you saved your file was with a maximized window, it should open with a maximized window again.
When I start AC the opening dialog box is always set to last profile used but I still get a window different in size from when I closed AC. I can not understand why. ? I have reset it again this morning to last profile used just to make sure, and it has done the same as yesturday, about 70% window.
