2015-06-03
02:36 PM
2024-03-26
02:43 PM
Aruzhan Ilaikova
2015-06-03 03:14 PM
2015-06-04 04:50 PM
2015-06-05 10:36 AM
2015-06-08 06:47 PM
laszlonagy wrote:
Graphisoft created a page in the Help Center:
http://helpcenter.graphisoft.com/technotes/operating-systems/windows-10/
There is not much info about it at the moment but it will be worth checking out from time to time as more information becomes available.
2015-06-09 10:24 AM
2015-06-09 11:03 AM
2015-08-10 12:48 PM
2015-08-13 01:23 AM
2015-08-13 01:35 AM
KeesW wrote:Actually my profile was showing my 3 1/2 year old computer that I just retired:) I've updated the profile to my new system though its not so different except that I now have faster overclocked CPU and MUCH better, larger and faster SSD's and better quality smaller case. If you want good SSD's now the way to go is the samsung pro line. Yes I like good gear and the system is maybe more than is required for archicad but I work with large photographic files as well in my hobby. I went for a system from IC3D which is aligned to the Graphisoft distributor here in Australia who make systems designed to run Archicad and other CAD software.
arcadia
Judging by the specifications of your computer you are obviously a gear freak! many years ago we had speed tests where users could test and compare their Archicad's performance against a common set of criteria. i had, for a brief period, the fastest computer that was tested. We should have something similar now. Not that it really matters - I suspect that your computer is far more powerful than you ever need but there was a slight glow of satisfaction in having the fastest.
Any suggestions out there?
