ac 17 is running in demo
Recently i upgraded my license from ac14 to ac17. i have installed ac17 in my system (win 7) then i plugged wibu key, below it showed wibu box is successfully installed. then i open ac 17 its running in demo mode.
can any give me a solution for this problem.
6 Replies 6
David Maudlin
selva1986:
Has the WIBU key been upgraded via the Graphisoft web site?
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
yes i have upgraded my license through graphisoft standalon 'license activation tool'
Can you still run version 14?
If so the WIBU key is still being recognised but may not have upgraded properly so check with the license activation tool again.
If 14 is not running then try plugging the WIBU key into another USB port.
Maybe try that anyway.
And when in doubt remove the key and restart your machine then replace the key.
A simple restart can sometimes do wonders.
yes. My ac 14 also running in demo. This problem is started after i upgraded to ac 17. Before its working ok.
When you installed 17, are you sure that you selected the correct protection key for installation of updated drivers? You would have had a choice of the plastic blue WIBU key (old keys) or the silver/metal Codemeter keyplug.
You can just re-install the proper driver to be sure:
http://www.graphisoft.com/downloads/protection_key.html
Maybe it is not the answer, but did you restart your system after the upgrade. It may have installed a new driver and it needs a system restart before it is loaded.
