archicad 19 goodies not installing
my downloaded archicad 19 goodies package refuses to install,,, saying archicd is open, close archicad and click install again ... help me please
You can't install the goodies while Archicad is running.
I you have closed Archicad and still can't install the goodies then I would restart your computer.
Then before you do anything else try to install the goodies.
If it still doesn't work maybe it is a Java version issue.
I know Archicad itself has problems installing if the wrong version of Java is detected.
wat version of java would u recomend for me bcos i have installed my java 8... As required... Please i need ur help please
From what I can tell Java 8u45 is the correct version for 19.
If you have anything newer you can try to in-install it and install Java 8u45 - available here ...
http://www.graphisoft.com/downloads/java.html
That may not be the issue though as I don't know if the goodies rely on Java to install.
I know Archicad and the hotfixes (updates) do.
To make sure Archicad is definitely not running go into your processes and see if it is listed there as running.
On a Windows system go to Task Manager.
I have no idea where to look if you are on a Mac.
If none of this works I am out of ideas for now.
