2016-08-15 07:40 PM
2016-08-17 02:39 PM
2016-08-17 07:03 PM
2016-08-18 06:22 PM
2016-08-18 06:40 PM
2016-08-19 04:33 AM
Will ARCHICAD File Converter run on Windows 7 and newer?This is from the file convertor download web page ... http://www.graphisoft.com/downloads/fileconverter.html
Yes. You can run it in "native" Windows 7 mode, we do not actually recommend running it in emulated "XP mode". The same applies for Windows 8 and 8.1. You might get an error message concerning missing MSVCsomething.DLL files. If you encounter this please download the missing DLLs from here.
ARCHICAD File Converter versions 9 and 10 run on Windows 10 only if QuickTime is installed otherwise the BugReporter aborts the starting process. ARCHICAD 17 is the last version that contains QuickTime.
2016-08-20 12:34 AM
2016-09-15 09:40 AM
