archicad replacement icons (mac)
schagemann
dear all,
i am sure we are not the only one who struggle following which AC version you are currently working in, particularly since the default AC logo has remained unchanged for quite some time...
... and so we decided to create our own and make it available for everyone - actually since we are trained architects like most of you, we made a few options...
1. column: transparent white outline
2. column: white
3. column: transparent
please download the respective versions from the following posts.
enjoy,
ds.
macinteract
Design Technology Managers.
All  on macOS | since AC 6
Archicad Framework > Smart Template 27
Smart Tree, Transmittal and Universal Label and other smart GDL Objects
By Architects for Architects.
Eszter Fulop
For those who have difficulty distinguishing the original launch icons, we’ve introduced new alternative icons that prominently display the version number for easier identification. You can find all the details about the icon changes in this Knowledge Base article:
https://community.graphisoft.com/t5/Getting-started/Introducing-alternative-launch-icons-for-Archica...
Please read it carefully, as the previous solution some of you used is incorrect and may cause Archicad to mistakenly be flagged as a pirated version. To avoid issues, kindly follow the guide in the article.
Thank you!
34 REPLIES 34
schagemann
to install simply replace the following:
replace logo in /Applications/Graphisoft/ArchiCAD 10/ArchiCAD.app/Contents/Resources/ArchiCAD.icns
to get past the package (ArchiCAD.app), simply right click and select show package contents.
macinteract
schagemann
replace logo in /Applications/Graphisoft/ArchiCAD 11/ArchiCAD.app/Contents/Resources/ArchiCAD.icns
macinteract
schagemann
replace logo in /Applications/Graphisoft/ArchiCAD 12/ArchiCAD.app/Contents/Resources/ArchiCAD.icns
macinteract
schagemann
btw. since we are on mac's we would not have a clue as to how you can do the same on anything else...
so if anyone knows please respond below and feel free to use the above logo's.
ds.
macinteract
schagemann, could you repost the AC13.zip file?
I thought you accidentally posted the same message 4 times and deleted one of them.
Only then did I notice that they are not identical posts but there was no way back.
As one AC-Talk user sometimes says: Someday, I'll get there.
schagemann
no worries.
replace logo in /Applications/Graphisoft/ArchiCAD 13/ArchiCAD.app/Contents/Resources/ArchiCAD.icns
;0)
macinteract
Erich
Schagemann,
What a nice set of icons and instructions. I did the same thing on my own but instead of a big number over the existing icon, I just changed the color cast for the icon. I find that is quicker to pick out on my screen.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
schagemann
another version and although this time they have changed the logo, at least on the mac the version number is still not displayed... thus:
macinteract
schagemann
replace logo in /Applications/Graphisoft/ArchiCAD 14/ArchiCAD.app/Contents/Resources/ArchiCAD.icns
macinteract
