Installation & update
axonometry view in v20
Any idea why archiCAD would ONLY show my building info in perspective view while in 3d and NOT in axonometry? ALL layers are on, and renovation settings are set to show all. This has been an issue from the moment I started using v20 and have been working in perspective, but it is time for me to figure out why this is happening.
Thanks!
TIM
17" MacBook PRO
16 GB RAM
1TB SSD
OSX 10.11.6
14 REPLIES 14
I know a thing or 2 about MACs like where JAVA and FlashPlayer are installed. After searching around, even in hidden folders, I can find no apps matching or even coming close to the name you mentioned. BTW, everything works fins in all the older versions. For some reason this is only an issue in v20
Unless it is related to this - but I don't think so.
http://archicad-talk.graphisoft.com/viewtopic.php?t=55946
I am all out of ideas (other than make sure Archicad and your video drivers are up to date - they are always good to check).
Thank you for your help!
David Maudlin
opart wrote:
Interestingly, "select all" DOES select items. This gave the upper left corner of the view a slight glow in the selection color, however when I tried dragging the view still nothing showed up.
Maybe there is an element far removed from the model that affects the Fit in Window command. You could go to each Story and Fit in Window to see if it shows up. Have you tried selecting one element in plan, right-clicking Show Selection/Marquee in 3D, then Fit in Window in the 3D view to see if that works?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Unfortunately the results are the same if I pick just one element to look at or if I try to view everything in the model file . . . .
