cannot create temporary documents
marox2023
Beginner
Hello, I have a problem. When starting Archicad 25, a "caution" box appears with the words "cannot create temporary documents". And after a few seconds, the program closes itself. It does not create a new file either. I tried deleting all the files that appear in the first page and the box remains. In the folder Graphisoft, there is no file "autosave-25". Could you please help?
6 REPLIES 6
Does your user profile have full read/write access to all of the folders it should on your local drive?
Sounds like a permission problem to me.
What operating system are you using?
marox2023
Beginner
Hello!
I am using Windows 10, if this is what you mean.
My archicad licence is for students. Till yesterday, I was using it but today this problem appeared.
Thank you for your reply!
Guru
You have disc space? Temp folder space? Run a disc cleanup, or what ever the eq. is on Mac?
If it was working before, then the problem isprobably not access permissions.
More likely a lack of hard drive space as Ling has suggested.
Free disc space: 30GB and I just deleted all the files in temporary folder. I tried to open Archicad again but the message remains.
Thank you!
Completely re-boot your machine.
That may clear the problem.
