2016-07-10 10:03 AM
2022-02-13 08:00 PM
I know this is an old thread but this was my solution.
Archicad21 on an old macPro 3.1 El Capitan. CineRender running beautifully until I decided to migrate my hdd to an ssd. Then the same CineRender message as per topic
However, if I boot the computer off the old hdd and run AC21 and access files from the ssd then CineRender is running as normal.
I have no idea why!!!! Some hardware glitch. So if anyone has recently ungraded a drive (or any other hardware for that matter, that may be the cause of the bug.
For me I do all my work booting as usual from the ssd but when I start rendering I reboot from hdd. Odd and somewhat inconvenient but hey, it works. Hope this helps some of you.
2022-02-14 01:37 AM
I would be guessing, if you are booting from two different drives, you effectively have 2 different operating systems.
They may be the same OS, but the settings are different.
I would be guessing it is different video drivers.
2022-02-14 09:16 AM
I performed a migration from hdd to ssd, so all files and settings were a perfect mirror making it impossible for any settings, drivers or preferences to be changed. Puzzling 🧐
