Installation & update
different wall displays for different plans
Could anyone tell me how to change the way a wall looks in different plans? I am trying to make a structural plan, where I want the wall to read only as lines and not show the material as a hatch. changing its properties (throughthe info box) will change it in the construction drg too.
9 REPLIES 9
David Pacifico
You'll need to change a display option.
In AC 10 look under Document/Set Model View/Model View Options
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
is there something similar in AC 9?
David Pacifico
Yes
Options/Display Options
Be sure Set up a Display Option Combination
David Pacifico, RA
thank you!! feel stupid...I should have thought of that!
I want some walls to appear dashed rather than a solid line. display options doesn't seemt to be an option here...any suggestions?
I still need to show some walls with a hatch, while others as lines. and some walls as dashed rather than solid lines. I know I should not change properties...since it changes the wall as a whole. Is the any way I can do such an operation in the structural plan view only?
Easiest is to export a simple-looking plan out to DWG and reimport, changing linetypes, layers, and colors to something else when it comes back in. You get just a 2D plan, but it will look right.
Richard
AC26 (since AC6.0), Win10
David Pacifico
In the Wall Settings you can choose a different line type for your wall but you can't have that just apply to a structural drawing.
You could make Detail around the whole floor plan, then in the detail, treat it as a 2D background. Layout the Background seperate from but right on top of the Structrual Info in Plotmaker. Not ideal but...
There might a trick of putting the parts you want to show dashed on a false story below and having it show one story up.
HTH
David Pacifico, RA
Aussie John
You can place a "white" hatch over the plan ( clear background of course) using a thick white pen.
Cheers John
[/size]
