‎2015-04-21 02:35 PM
‎2015-04-22 05:43 AM
‎2015-04-22 12:14 PM
‎2015-04-22 04:37 PM
laszlonagy wrote:thank you sir it's true i was made the non Unicode as Egypt . it should be united states
You are located in Egypt. Are you using Arabic Windows?
That might have something to do with it.
Do you have some right-to-left writing order setting in your system? That may be causing it.
‎2015-04-22 04:48 PM
‎2015-04-23 02:51 AM
laszlonagy wrote:You may even have to re-document your model.
After changing any such system setting you will probably have to restart ArchiCAD for the changes to take effect.
