font problem
please give me advise for the image in Attachment the 550+ it's appear
it should appear +550
5 Replies 5
Working fine for me.
Could it be your Operating System language/number format settings?
You are located in Egypt. Are you using Arabic Windows?
That might have something to do with it.
Do you have some right-to-left writing order setting in your system? That may be causing it.
thank you sir it's true i was made the non Unicode as Egypt . it should be united states
So did you change some setting and it is now working fine?
After changing any such system setting you will probably have to restart ArchiCAD for the changes to take effect.
You may even have to re-document your model.
New dimensions and height markers will have the new settings but existing ones may retain the old settings.
At least that is what happens to me if I ever try to get rid of the comma for thousands in numbers (dimensions).
i.e. 1,000 to 1 000.
