graphic cart
i'm looking for a new videocard and I found the Radeon X1950 GT (512MB DDR3 256bit) and was wondering if this is a good card in combination with Archicad11?
Tnx John
3 Replies 3
Probably pretty good.
AC takes advantage of the card's potential mainly in the 3D Window.
I think this is a pretty strong card, it will serve you well for a long time.
I´m still not decided between the 1950 PRO and the 8600 GT series.
I was wondering if the 8600GT serie wouldn't be a better choice for Archicad because of the DirectX10 support.
some specs....
Grafische chip
Type GeForce 8600 GT
Snelheid 540 MHz
Shader Model 4.0
Full Screen Anti Aliasing 16
DirectX Versie 10
OpenGL Versie 2
Geheugen
Capaciteit 512 MB aanwezig
Type GDDR3
Snelheid 1400 MHz
Interface 128 bit
Grafische chip
Type Radeon X1950 PRO
Snelheid 580 MHz
Pixel-Shader 36
Vertex-Shader 8
Shader Model 3.0
Geheugen
Capaciteit 256 MB aanwezig
Type GDDR3
Snelheid 1400 MHz
Interface 256 bit
The NVIDIA 8800 GTS w/ 640mb ram is a good deal for the power it has. It will be adequate for a couple of years at least.
I am happy with it.
Directx 10 may become an issue down the road a bit (year or so). Right now not much software is utilizing it. I have no idea whether AC12 will be hip to it or not.
