material textures "not sticking"
i'm having issues with specific materials where the assigned texture and settings are reverting back to a default or not having an assigned texture.
i thought it may have been related to view sets (i.e. specific values for texture, transparency, attenualtion, emmision etc. being saved and being reset to those saved) however i've noted the behaviour after opening a file (and before making any changes) and also when using views (not saved views) to navigate).
It seems to happen with only specific materials, and while i will try changing the assigned material to another, it is stll annoying.
Has anyone has similar experience or any insight on what is happening?
I noticed this also. I had to change the material to another and back again. I had not loaded the library with the texture before and thought there might be some issue with archicad successfully "re-aquatinting" the texture with the material. Perhaps a bug.
